| Version(s): | SE or 95 | ||
| Area: | Text | ||
| Subarea: | General | ||
Is there a text size limit in MicroStation?
MicroStation 95 has a maximum text height of 12,884,898 UORs.
To arrive at the maximum text height divide 12,884,898 by the UORs per Sub-Unit,
then divide the result by the number of Sub-Units per Master Unit.
Microstation SE has a configuration variable,
MS_enhancedprecision, which allows accuracy of less than 1/10000 of a UOR.
