| Version(s): | 08.11.09.357 | ||
| Environment: | Windows XP 32 bit | ||
| Area: | Text | ||
| Subarea: | N\A | ||
| Original Author: | Judy Wong, Bentley Technical Support Group | ||
Unable to load dialog "Text Editor - Word Processor"
User is getting error message "Unable to load/create dialog item of type 'HTML', id = 41510001 from dialog "Text Editor - Word Processor" when using place text tool in MicroStation V8i / MicroStation XM, OS is WindowXP / Window 7
The solution was to manually unregister and re-register the triedit.dll
and dhtmled.ocx files:
(Please note that the above solution is valid for Windows XP only)
For Windows 7 ; This may work for MicroStation V8 XM Edition.
Please install the DHTML editing control from Microsoft:
http://www.microsoft.com/en-au/download/details.aspx?id=8956
http://communities.bentley.com/products/microstation/w/microstation__wiki/7385.text-editor-word-processor-error-unable-to-loadcreate-dialog-item-of-type-html
