| Version(s): | 08.05.02.27 | ||
| Area: | Text | ||
| Subarea: | Text Styles | ||
What do the little arrows on the icons mean in the text style editor?
A text style icon with the little arrow means that the text style definition is coming from a dgnlib (text style library).
Icons without the arrow means that the style was defined in the active design file rather than the definition being read from the dgnlib.
But when it turns blue, it means that the text style in the dgnlib has been modified and is now out-of-sync with the definition in the active design file.
