| Version(s): | 08.05.02.27 | ||
| Area: | Text | ||
| Subarea: | General | ||
What happens to text when upgrading V7 files?
Does it get assigned to a text style?
When saving a MicroStation V7 file to MicroStation V8 no text style is added.
The default is "Text Style (None)", which is the logical choice since the MicroStation version 7 format did not include text styles.
