| Version(s): | V8 | ||
| Area: | Text | ||
| Subarea: | Fonts | ||
How to place characters in the ASCII 127-255 range.
If you know the corresponding number (use fontedit.ma), you may place the character by putting a backward slash before the number.
For example, if number 176 is the character that you wish to place, type "\176" in the text editor.
