| Version(s): | 08.00.00.00 | ||
| Area: | Text | ||
| Subarea: | Fields | ||
How to re-order data fields?
1. Place the data fields into a selection set.
2. Identify each field in the order you want them to fill.
3. Press CTRL + G to group them.
4. Press CTRL + U to ungroup them.
They are now re-ordered.
