Fonts - Text - MicroStation
Arabic Text Displays Backwards
Arabic characters overlap in View display
Are True Type fonts installed with MicroStation V8?
Assign different font to specific tags
Can not see SHX font types in Font dialog in MicroStation v8.
Can the Degree Display Character be set using the UPF or PCF?
Diameter Symbol
ERR: Replaced missing MicroStation RSC font (font number)
ERROR: Character 201 does not have a Level=63 shape.
FT= key-in font from resource file
Filled MicroStation Fonts are not displaying Filled in DWG file as an SHX Font.
Font 43 (LOW_RES_FILLED) has strange jagged edges in MicroStation V8i
Fonts not displaying correctly in MicroStation /J
How characters in a font can be modified in MicroStation J.
How do I insert a diameter symbol in text
How to Disable the Autostack Function
How to auto stack MicroStation USTN Fonts (.rsc fonts)?
How to convert MicroStation fonts (*.rsc) to autoCAD fonts (*.shx/shp).
How to disable the use of True Type Font, USTN Fonts and/or SHX Fonts in V8
How to locate RSC Files in MicroStation
How to place characters in the ASCII 127-255 range
Inch mark moves a space away in dimension with fractions
Insert Symbol of "diameter" became an "asterisk" sign
Justification and Origin of Text Differs
Missing AutoCAD SHX font
Missing Font
Missing font in MicroStation V8i
Need to manage fonts. (Rename, Move, Description, & Number)
Placing text strings using multiple fonts
RSC font not loading in Font Utilities
Symbol not available from Symbols dialog
Text characters displaying differently between users MicroStation installs
Thai Accent Marks Overlap
True Type Font Changes
Unicode Chinese font cannot be displayed in Tags
Using True Type Fonts
View update using TTFonts in MicroStation V8.1
What does the "Additional Font Files" option on the Install process do?
Wrong Character for Plus/Minus Symbol
Wrong Characters for Degree Symbol
