| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | Analysis Solutions | ||
| Subarea: | Pushover Analysis | ||
I have a concrete structure. I am attempting to do a Pushover Analysis and getting errors. I cannot figure out why.
As of now, Pushover Analysis in STAAD.Pro is restricted to steel structures only. If you attempt to do a pushover analysis on a concrete structure, the software would generate the following error in the analysis output file
**ERROR : ONLY MATERIAL STEEL IS CONSIDERED FOR PUSHOVER ANALYSIS.
