| Version(s): | 08.05.00. | ||
| Area: | Text | ||
| Subarea: | General | ||
Can not delete Text nodes from file--User has text nodes in the file that can not be identified or deleted.
The association of the text node was stretched away from the node number. Try the following steps:
1. Do a "Select By Attributes" to find the text node;
2. Find the level of the text node;
3.Turn off all levels except the level of the text node;
4. Remove the text nodes.
