| Version(s): | 08.05.01.25 | ||
| Area: | Text | ||
| Subarea: | N\A | ||
How to change text case in MIcroStation V8.
In MicroStation V8, key-in the following: vba run [TextExamples]ChangeCase
Steps:
1. Make a selection set or a fence around the text desired to change. Tip: Use a Fence, set to Clip, around an individual line(s) to change individual text lines within text nodes.
2. Key-in: vba run [TextExamples]ChangeCase (A dialog will open).
3. Set settings are desired and press "OK".
4. Press Exit when done to close the dialog and unload the application.
Note:
This application is an example MVBA function.
http://communities.bentley.com/products/microstation/w/microstation__wiki/14548.change-text-case
