| Version(s): | All | ||
| Area: | Analysis Solutions | ||
| Subarea: | Response Spectrum Analysis | ||
I am attempting to run a spectral analysis of a structure. I have a design spectrum in terms of %ground acceleration and i am trying to determine how the scale factor works. Could you direct me on what the scale factor is? Also should I be entering the % ground acceleration into the chart or the actual acceleration?
The spectral accelerations entered, after multiplication by the scale factor, must be in the current length units of the STAAD input. For example, if the spectral acceleration is in g's (%ground acceleration) and the current units are inches, then the scale factor must be 386.088; or 32.17 for feet; or 9.80665 for meters. The scale factor is simply the conversion factor from the units of the spectral acceleration to the current units of the STAAD input data.
