| | Product: | MicroStation | |
| | Version: | 08.05.xx.xx | |
| | Environment: | N\A | |
| | Area: | Text | |
| | Subarea: | General | |
How To
How to copy \ increment text at a desired location.
- Use place text to type the number
- Select copy\increment text and fill in the tag increment
- Select the text
- Type P In X axis box and change data point key in to Distance(di=)
- Type the distance in which you want to place the increased text and the number of times to be done (example 2 | 1440)
Note: places data points relative to last data point
6. Press enter
http://communities.bentley.com/products/microstation/microstation_annotations/f/19566/t/20000.aspx
Other language sources
| | Original Author: | Maria Munoz | |
