| Version: | 08.11.XX.XX | ||
| Area: | Text | ||
| Subarea: | General |
While trying to place a text by key-in with the content "Q/<Number>" MicroStation is closed immediately without any message.
The key-in Q/ is analyzed as "Quit" command and interpreted to close the program.
Key-in “set parseall off” causes that key-ins are not analyzed anymore and the text can be placed.
| Original Author: | Jutta Eisenhauer |
