Applies To | |||
Product(s): | STAAD.Foundation Advanced | ||
Version(s): | All | ||
Environment: | N/A | ||
Area: | Analysis Solutions | ||
Subarea: | Response Spectrum Analysis | ||
Original Author: | Jason Coleman Bentley Technical Support Group | ||
Input required for instructing STAAD to include MISSING MASS when performing a response spectrum analysis.
MIS f6
The term MIS tells STAAD to consider missing mass. In other words, if the word MIS is omitted, the missing mass calculations are not performed.
f6 is the spectral acceleration for the missing mass mode in units of length/sec2. This value is not multiplied by SCALE. If f6 is zero (0) or not entered, the spectral acceleration will be based on Item (2) described next.
ZPA f7
This input is required only if f6 as described in Item 1 is not provided or set to zero. f7 is not used if f6 is entered.
f7 is the frequency at which the spectral acceleration for the missing mass mode is evaluated (if f6 is not entered) from the input period versus acceleration pairs. If f7 is not specified, or set to zero, STAAD will assume a value of 33 Hz.
FF1 f8
This term is required only if the ASCE modal combination method is used. It is the f1 term in equation 3.2-23 of the ASCE 4-98 standard. It represents a frequency and has units of Hz. Its default value is 2 Hz.
FF2 f9
This term also is required only if the ASCE modal combination method is used. It is the f2 term in equation 3.2-23 of the ASCE 4-98 standard. It too represents a frequency and has units of Hz. Its default value is 33 Hz. If f9 is assigned a value less than f8, f9 is reset to 33 Hz
Procedure used by STAAD for combining the response from the missing mass mode with those from the calculated modes.
SPECTRUM CQC X 1.0 ACC SCALE 9.81 CDAMP LOG MIS
SPECTRUM ASCE Z 1 ACC SCALE 386.08 DAMP 0.04 MIS ZPA
How is the missing mass mode evaluated?
Using equation 3.2-8 of ASCE 4-98 :
{MissMassMode} = { {Ub} – SUM[PartFact(i) {Phi(i)} ] }. Sum over modes.
[K]{X0} = [ M ] {MissMassMode} * (Sa miss)
(Sa miss) = spectral acceleration (based on user input accel or input zpa frequency.
The missing mass mode is the difference between the static deformation due to a 1 g static load in a global direction and the sum of the responses of each mode extracted due to a 1g excitation. This is the amount of deformation that cannot be represented by the modes that were extracted.
The modes that were not extracted also have a dynamic component that the missing mass mode cannot represent (non-rigid response). It is assumed that if all of the modes up to the ZPA are included, then there will be very little non-rigid response. ASCE4-98 and other documents describe how to calculate the ZPA from the test data from the site.
