| Version(s): | 08.11.05.17 | ||
| Area: | Text | ||
| Subarea: | General | ||
| Original Author: | Jeremy Pry, Bentley Technical Support Group | ||
TT Text not visible Front view
When text using a True Type font is placed in Top view, it is not
visible in Front or Right view. Steps to reproduce:
1. Open new 3D file
2. Place a piece of text in Top view using MicroStation font
3. Place a piece of text in Top view using True Type font
4. In Front or Right view, notice that text with MS font is visible,
while text with TT font is not
5. Save, and open same file in 08.05.02.70. Both pieces of text are
now visible in Front view
This problem can be resolved by turning Anti-alias text OFF. Go to Workspace > Preferences > View Options, then change the Anti-alias Text drop down from ON to OFF
