| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | Analysis Solutions | ||
| Subarea: | Time History Analysis | ||
| Original Author: | Sye Chakraborty Bentley Technical Support Group | ||
How do I apply two harmonic loads PSinwt and QCoswt at the same loading point simultaneouly?
The input is as follows. Please refer to example 22 in the STAAD.Pro examples manual for additional information.
DEFINE TIME HISTORY
TYPE 1 FORCE
FUNCTION SINE
AMPLITUDE 5.3 FREQUENCY 60 CYCLES 100
TYPE 2 FORCE
FUNCTION COSINE
AMPLITUDE 7.8 FREQUENCY 80 CYCLES 100
ARRIVAL TIMES
0.0 3.0
DAMPING 0.075
LOAD 2
SELFWEIGHT X 1.0
SELFWEIGHT Y 1.0
SELFWEIGHT Z 1.0
JOINT LOAD
9 25 FX 14.0
9 25 FY 14.0
9 25 FZ 14.0
TIME LOAD
9 25 FX 1 1
9 25 FX 2 2
