| Version(s): | V8i | ||
| Environment: | V8i | ||
| Area: | Gereral | ||
| Subarea: | N/A | ||
| Original Author: | Bikash Majumder, Bentley Technical Support Group | ||
The desired company name to be reflected in reports and
printouts of STAAD.Pro results to be entered while asked for during installation
of STAAD.Pro. However, if the required entry was skipped by the user, he / she
may enter the company name by modifying one registry sub-key as described
below:
a) Go to command prompt
b) Type Regedit and hit enter
c) expand HKEY_CLASSES_ROOT
d) Scroll down through the displayed lists and expand STAADPro
e) Select 2007 (20.07.10 for STAAD.Pro SS5 or 20.07.11 for STAAD.Pro SS6)
f) Double Click on Username
g) Enter your desired Company name as shown in attached screen capture.
