| Version(s): | 08.05.02.35 | ||
| Environment: | Windows 2000 | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles | ||
Problems with extension lines on dimensions. Dimension lines have extension on both right and left side after the extension line.
Element > Dimension Styles > Terminators and under Geometry change the Min leader value to 1. Currently it is set to 0
