| Version(s): | 08.01.02.15, V8i (Select Series), CONNECT Edition | ||
| Area: | Dimensions | ||
| Subarea: | General | ||
When trying to dimension a scaled reference drawing the dimesions are
not correct they are not scaled to the reference file.
MicroStation V8 2004 Edition:
Element > Dimension Styles > Placement > toggle on Reference Scale:
MicroStation V8i (Select Series):
Element > Dimension Styles > Units tab > toggle on Reference Scale
MicroStation CONNECT Edition:
Drawing workflow > Annotate > Dimensioning tools > click the little arrow to open Dimension Styles > Units tab > toggle on Reference Scale:
