| Version(s): | 08.05.01.25 | ||
| Area: | Tools | ||
| Subarea: | N\A | ||
Dimensions that were placed with the Angular Dimension command have tolerances with a plus and a minus.
When the dimensions were placed the Tolerance Generation toggled was on.
Those that do not have a tolerance the Tolerance Generation toggle was off.
