| Version(s): | 08.09.00.92 | ||
| Area: | Dimensions | ||
| Subarea: | General | ||
Does the active angle affect the Rotated Box or Rotated Hexagon setting for the Text Frame in the dimension settings?
The active angle has no effect on the rotation angle of the text frame. When the text frame is selected to be one of the rotated options, the box is rotated 45 degrees and the hexagon is rotated 30 degrees.
