| Version(s): | 08.05.02.35 | ||
| Area: | Dimensions | ||
| Subarea: | General | ||
Dual Dimensions appear to be floating above the dimension line.
Dimension text with Dual Dimensions appear to be above the dimension,
appearing like a fraction and the change dimension tool has no
affect on the lower margin values.
Product: MicroStation V8 2004 Edition
Version: 08.05.02.35
Area: Dimension/Measure
The key-in: CHANGE DIMENSION JUSTIFICATION FROMSTYLE can be used.
http://communities.bentley.com/communities/other_communities/askinga/w/askinga/change-dimension-text-justification
