| Version(s): | 08.05.02.35 | ||
| Area: | Dimensions | ||
| Subarea: | General | ||
Ghost dimension appears when file is referenced.
When file is referenced there is a ghost dimension that is showing up.
When you open the file that the dimension is showing to be in, it is not there.
The dimension is in the file, just in the wrong location. The association of the dimension is causing the location of the dimension to shift. Dropping the association on the dimension will correct the problem. This issue is resolved in MicroStation V8 XM Edition.
