| Version(s): | All | ||
| Area: | Design Solutions | ||
| Subarea: | General Design Solutions | ||
Following are the design codes supported by STAAD.Pro SS5. Users need to have suitable licenses as stated below in order to use these design codes.
STAAD US Standard Design Code License pack comprises the licenses of following design codes:
American Steel Design per AISC 360
Unified Specification - Steel member design per ANSI/AISC 360-05 and 360-10,
Since the ASD and the LRFD method are both addressed in those specifications,
they are referred to as UNIFIED.
9th Edition ASD and 3rd edition LRFD
Design per American Cold Formed Steel Code – AISI 1996
American Concrete Design ACI 318 - Four versions of the
code are currently implemented: the 1999, 2002, 2005, and 2008 editions
American Timber Design- AITC 1984 and AITC 1994.
STAAD US Special Design code pack license pack comprises the licenses of following design codes.
Steel Design per AASHTO Specifications ASD and LRFD
American Aluminum Code based on ASD 1994 Sixth Edition (October, 1994).
American Transmission Tower Design Code Steel Design per ASCE 10 -97
Steel Design per American Petroleum Institute Code - based on the API 2A-WSD
standard, 21st Edition.
ANSI/AISC N690-1994 Code – needs the STAAD Nuclear Design Codes
SELECT Code Pack.
ANSI/AISC N690-1984 Code
ASME NF 3000 - 1974 & 1977 Codes
ASME NF 3000 - 1989 Code
ASME NF 3000 - 1998 Code
ASME NF 3000 - 2001 & 2004 Codes requires Nuclear Design Codes
SELECT Code Pack
STAAD Asia Design SELECT Code Pack comprises the licenses of following design codes:
Chinese Steel Design – GB 50017
Chinese Concrete
Singapore Concrete – CP65
STAAD UK Super Code license pack supports the UK codes (typically BS5950, BS8110, BS5400) and Euro codes as below with all National Annexes.
British:
BS 5950-1:2000 (steel)
BS 5950– 5:1998 (cold formed steel)
BS 8110-1:1997 (concrete)
BS 5400- 3:1982 (steel, concrete and composite bridges with amendment # 4051
and 6488)
BS 8700- 1997 (concrete structures for retaining aqueous liquids)
Euro:
EC2 ENV 1992-1-1:1991 (concrete)
EC3 DD ENV 1993-11:1992 (steel)
EC3 DD ENV 1993-11:2005 (steel)
EC5 Timber Design Per EC 5: Part 1-1
The STAAD ECC Super Code license pack supports all European codes that were previously covered by the STAAD packs Eurozone (typically French, Spanish and
German codes), North Eurozone (typically Norwegian and Finnish codes), and East Eurozone (typically Russian codes) as stated below with all National Annexes.
Euro:
Russian:
SNiP 2.03.01-84 (concrete)
SP 52-101-2003 (concrete)
SNiP 2.23-81 (1999) (steel)
SP 16.13330.2011 (steel)
German:
DIN 1045-1:2001 (concrete)
DIN 18800: 1 & 2 (steel)
France:
B.A.E.L- 1991 (concrete)
CM66 1977 (steel)
Norway:
NS 3472/NDP (steel)
NORSK N-004 (steel)
NS3473 (concrete)
Finnish:
B4 (concrete)
B7 (steel)
Spanish:
NBE –MV103-1992 (steel)
EHE (concrete)
Swedish:
BSK 99 (steel)
BBK 94 (concrete)
Dutch:
NEN 6770 (steel)
Danish:
DS412 (steel).
Cyprus:
Cypriot Codes - Concrete Design in Cyprus
STAAD CAN/AUS/SA design code pack includes the Licenses of following design code:
Canadian Codes - Concrete Design per CSA Standard A23.3-94
Steel Design per CSA Standard CAN/CSA-S16-01
Design Per Canadian Cold Formed Steel Code S136-94
Wood Design Per CSA Standard CAN/CSA-086-01
Steel Design per CSA Standard CAN/CSA-S16-09
Australian Codes - Concrete Design per AS 3600 – 2001
Steel Design per AS 4100 – 1998
South African Codes - Concrete Design per SABS-0100-1
STAAD Indian Design Code pack includes the licenses of Following design codes:
Indian Codes - Concrete Design per IS 456
Concrete Design per IS 13920
Steel Design per IS 800 – 1984
Steel Design per IS 800 – 2007
Steel Design per IS 802 – 1995
Design per Indian Cold Formed Steel Code 801 – 1975
STAAD Japanese Design Code pack includes the licenses of Following design codes:
Japanese Codes - Concrete Design Per 1991 AIJ
Steel Design Per 2005 AIJ
Steel Design Per 2002 AIJ
STAAD Middle east Design Code pack includes the licenses of following design codes:
Egyptian 205 – Code of Practice for Steel Construction
TS 500 – Turkish Concrete Design Code
STAAD Latin American Design Code Pack comprises the licenses of following Design Codes:
Mexican Codes - Concrete Design Per MEX NTC 1987
Steel Design Per NTC 1987
