| Version(s): | 08.05.02.27 | ||
| Area: | Dimensions | ||
| Subarea: | General | ||
Having trouble with Dimension Scales in MicroStation V8.
When placing a dimension at 1:20 scale the text size is too small.
The text style that the Dimension style is calling is called 1-to5-scale. This means that the text size is at a 1:5 scale and not1:20. There is a text style called 1-to-20 this text style will need to be used instead.
