How is the Polar Moment of Inertia calcu...
 Product(s):MICROSTATION
 Version(s):08.05.02.27
 Environment: N\A
 Area: Measure
 Subarea: N\A
How is the Polar Moment of Inertia calculated about the Z axis for the
Measure Area tool?
Product: MicroStation V8 2004 Edition
Version: 08.05.02.27
Area: Dimension/Measure
The Polar Moment of Inertia or Torsional Stress is calculated by adding the Moment of Inertia for the X and Y axis' due to the Per perdicular Axis Thorem.
Jz=Ix+Iy
More information can be located at http://www.efunda.com/math/areas/MomentOfInertia.cfm?Moment=xc
