Applies To | |||
Product(s): | MICROSTATION | ||
Version(s): | 08.05.02.15 | ||
Environment: | N\A | ||
Area: | Dimensions | ||
Subarea: | Dim Styles | ||
Original Author: | Bentley Technical Support Group | ||
How to access "XM style" dimension styles dialog in MicroStation V8 2004 Edition?
How to select, edit and/or delete multiple dimension styles?
Product: MicroStation V8 2004 Edition
Version: 08.05.02.15
Area: Dimension/Measure
The following keyin will load and open the Dimension Style Dialog:
Key-in: MDL LOAD DIMSTYLE;DIALOG DIMSTYLE OPEN
http://communities.bentley.com/products/microstation/w/microstation__wiki/microstation-dimensions
