Document Information
Document Type: FAQ
Product(s): LEAP CONSPAN/Precast/Prestressed Girder
Version(s): All
Original Author: Bentley Technical Support GroupĀ - VM
QUESTION: Camber and Deflection - Is the Diaphragm load considered as part of the total self-weight of the Beam?
ANSWER:
For camber and deflection, the Diaphragm load is not considered as part of the Total self weight of the beam.
