| Version(s): | 05.07.00.41 | ||
| Area: | Dimensions | ||
| Subarea: | General | ||
How to change the size of the spacing between the Dimension Text and the Dimension Line.
This spacing is set in the Element> Dimension> Tolerance> Lower Margin dimension setting. This value is a function of the Text height, so a value in this filed of 1 will correspond to a space that is equal to the Text Height in your dimension.
Quick Tip: To have your dimension text placed below the Dimension line, add 1 to the current Lower Margin setting and make the value negative (-).
