| | Applies To | | |
| | Product(s): | MICROSTATION | |
| | Version(s): | 07.01.04.10 | |
| | Environment: | N\A | |
| | Area: | Dimensions | |
| | Subarea: | General | |
| | Original Author: | Bentley Technical Support Group | |
How to dimension in Inches in MicroStation J?
In order to dimension in sub-units, MicroStation needs to be 'tricked' into reading sub-units. To dimension in Inches, here are the steps:
- Go to Settings > Design File > Working Units and change the master unit label to "In" or double quotes for the representation of the Inch mark.
- Go to Element > Dimensions > Units and change the Format to AEC.
- Set the Label to X1/2'.
- Change the Scale Factor to 12
- Next place a dimension, the dimensions will now appear as Inches instead of Feet and Inches.
