| Version(s): | 05.xx.xx.xx | ||
| Area: | Dimensions | ||
| Subarea: | General | ||
We would like to eliminate the space between the master units and sub
units when using automatic dimensioning in MicroStation v5.
Unfortunately there is no method to eliminate the space between the characters. This command has operated this way for 14 years and we've never had a request for this. The command cannot be changed but I will file a Customer Request for a change if possible in a future version.
