| Version(s): | 08.05.02.27 | ||
| Area: | Dimensions | ||
| Subarea: | General | ||
How to group the dimension items.
The dimension associations are turned off; the items are being drawn as individual items.
This happens when "Set compatible Dimensions" is turned on. We need to do a "SET COMPATIBLE DIMENSIONS OFF".
