| Version: | /J, V8i | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles |
How to remove bearings from the dimension line labels?
Go to Edit > Dimensions > Unit Format > under Angle Format change display to D.DDDD
In V8i :
Go to Element > Dimension Styles > Units tab > under Angle Format change display to D.DDDD
