| Version(s): | 08.09.00.92 | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles | ||
How to see all of the dimension settings.
As some of the dimension attributes seem to be missing with the new dimension style dialog box in MicroStation XM.
Under the Advanced tab, set the method to Editing. All of the dimension style attributes will be listed that may not be displayed under the other tabs in the dimension style dialog.
