| Version(s): | All | ||
| Area: | Concrete Design | ||
| Subarea: | General Concrete Design Solutions | ||
Can I change the strength reduction factors in the program? For example: For a tied concrete column, I assume that the current value is 0.70. Can it be changed to 0.65?
The answer is unfortunately no. You can only specify if it is a Tied column or a Spirally Reinforced column.
