| Version(s): | All | ||
| Area: | Concrete Design | ||
| Subarea: | General Concrete Design Solutions | ||
| Original Author: | Surojit Ghosh | ||
Why EC2 code is not available in batch the mode of concrete design in STAAD.Pro?
Since STAAD.Pro V8i Select Series 6 version, Euro code for concrete design (EC2 code) is not available in the batch mode of concrete design. This design code is available only in the RC Designer mode (in V8i version) or Advanced Concrete Design workflow (in CONNECT Edition). All the updates and enhancements of this code has been implemented in the Advanced Concrete Design workflow. Once the analysis is complete, go to the Advanced Concrete Design workflow:
In older versions of STAAD.Pro (V8i and older) the option can be accessed as shown next
