| Version(s): | 08.05.00.64 | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles | ||
How to suppress zero feet/inch in DWG file?
Leading Zero option does not work in DWG file.
In AutoCAD it is called "Suppress Zero Inch" and can be accessed in the Dimension Style dialog box. In MicroStation, the "display sub units" flag must be turned on.
Zero Sub Unit suppression:
Key-in:
mdl load calculat; calculator mdlDimStyle_setBoolIntProp(mdlDimStyle_getActive (), X, 1078)
X=1 means show the Sub Unit value even if it is zero.
X=0 means hide the Sub Unit value even if it is zero.
Zero Master Unit suppression:
Key-in:
mdl load calculat; calculator mdlDimStyle_setBoolIntProp(dgnDimStyle_getActiveFromModelRef (0), X, 1041)
X=1 means show the Master Unit value even if it is zero.
X=0 means hide the Master Unit value if it is zero.
Notes:
