| Version(s): | 08.05.02.48 | ||
| Area: | Dimensions | ||
| Subarea: | General | ||
In Microstation J one could modify where a dimension was pointing to whether the extension line was turned on or off, but in V8 the extension line must be turned on in order to modify. Is there a setting where this could be changed?
Key-in "Change Dimension extension toggle". Then select the end of the dimension line.
