Design parameters not considered for design
Product(s):STAAD.Pro
Version(s):ALL
Environment: ALL
Area: Concrete Design
Subarea: General Concrete Design Solutions
Original Author:Sye Chakraborty, Bentley Technical Support Group
I am carrying out a concrete design but my design parameters are being ignored by STAAD.Pro during the design. Why ?
Ensure that the design parameters are specified before the design commands in the input editor. If these parameters appear after the design command, the design process will not use these and will continue to use the default values. The two scenarios are explained below
Incorrect sequence of commands ( design parameters will be ignored by STAAD.Pro )
START CONCRETE DESIGN
CODE ACI
DESIGN ELEMENT 63 67 71
CLB 0.125 MEMB 63 67 71
FC 576 MEMB 63 67 71
END CONCRETE DESIGN
Correct sequence of commands ( design parameters will be considered by STAAD.Pro )
CODE ACI
END CONCRETE DESIGN
To achieve this graphically, select the last design parameter ( or the last command right before the DESIGN command, if there are no design parameters defined ) from within the tree structure on the right and then click on the Define Parameters button. Choose the appropriate parameter and value for it. Check the "After Current" check box within the Design Parameters dialog box and then click on Add. This will ensure that the design parameter gets added before the DESIGN command (or the CHECK CODE/SELECT command if you are carrying out steel design)
Although the example above relates to concrete design, the same is true for ANY other design ( like steel, timber, aluminum etc. ) as well.
