| Version(s): | 08.05.02.15 | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles | ||
The dimension line is not going up to the terminator endpoint when
placing a dimension.
Product: MicroStation V8 2004 Edition
Version: 08.05.02.15
Area: Dimension/Measure
The problem is due to a setting in a DWG dimension setting that was
maintained when the DWG was saved to a dgn.
In order to resolve this issue the following key-in needs to be used:
mdl load calculat; calculator mdlDimStyle_setBoolIntProp (dgnDim
Style_getActiveFromModelRef (0), VALUE, FLAG)
Where:
VALUE = 1 ON, 0 OFF
FLAG = 717 arrow, 718 Dot, 719 Origin, 720, Stroke
If the value is set to 0, the dimension line will run up to the end of
the terminator. If this is set to 1, the dimension line will run up to
the start of the terminator and leave a gap.
