Product: | MicroStation | ||
Version: | V8, XM, V8i, CONNECT | ||
Environment: | N\A | ||
Area: | Dimensions | ||
Subarea: | Dim Styles |
What controls the in-line leader length when setting the Dimension Style?
The Leader setting is found under Text in the dimension settings.
The in-line leader length is based upon the minimum leader value found in Dimension Style settings.
It is found under the Text Tab and is a function of Text Height units.
How to create a dimension style
Original Author: | Bentley Technical Support Group |
