| Version(s): | 08.05.02.27 | ||
| Area: | Dimensions | ||
| Subarea: | Notes | ||
Element Information on a place note leader line in the details what does the A stand for?
The A appears after the Point x,y data.
The A stands for association. This association is between the line and the text. If you place a note without text the A will not appear.
