| Version(s): | 08.09.00.92 | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles | ||
What does the check mark or triangle symbol mean displayed next to a dimension style in the Dimension Styles dialog box?
The check mark signifies that the dimension style is in synch with the dgnlib file that is being read in through the ms_dgnliblist variable. If the triangle or Delta symbol is displayed, it is signifying that the setting in the dimension style has changed between the local style and the style from the library.
