Document Type: FAQ
Product(s): LEAP RCPIER/Substructure
Version(s): All
Original Author: Bentley Technical Support Group - VM
ANSWER:
RC-PIER takes the portions of the drilled shaft below fixity point as a member supported laterally. In this case, only the axial load is considered. For the portion of the drilled shaft above fixity point, RC-PIER assumes there are no lateral supports. Therefore, it is designed exactly the same as a reinforced column, taking into consideration of both axial load and moments.
