| Version(s): | 08.05.02.15 | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles | ||
When a dimension is placed, the single quote (') and the quotation mark (") is not displayed.
Go to Element > Dimension Styles > Units.
Uncheck "Use Working Units" toggle and change the working unit labels from ft and in to ' and ".
