| Version(s): | 08.05.02.27 | ||
| Area: | Dimensions | ||
| Subarea: | General | ||
When opening a V7 file that was upgraded to V8 the dimensions are being exploded.
Product: MicroStation V8 2004 Edition
Version: 08.05.02.27
Area: Dimension/Measure
The elements were still dimensions, they were just not moving together. The Dimension compatibility was turned on. Had user key-in "Set Compatible Dimension off". This allowed the dimension to move together.
