Column Design -- crack control check
Document Information
Document Type: FAQ
Product(s): LEAP RCPIER/Substructure
Version(s): All
Original Author: Bentley Technical Support Group - VM
QUESTION: Column design – does the program perform crack control check as per AASHTO 5.6.7 for service load combinations?
ANSWER:
Currently the program is not performing the control of cracking check per AASHTO 5.6.7.
This check is available in Pier Cap design.
