When using the place note tool the inline leader is above the text and not in the Center
 Product:MicroStation
 Version:V8, V8i
 Environment:N\A
 Area:Dimensions
 Subarea:Dim Styles
When using the place note tool the inline leader is above the text and not in the Center.
  1. Go to Element > Dimension Styles
  2. Open Advanced tab
  3. Expand Notes
  4. Click next to Edit About and set this to Center. This will then place in-line leader in the center.
Other language sources
