| Version(s): | 08.05.00.34 | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles | ||
Which key-in controls whether the dimension lines should extend all the way to the extension lines?
mdl load calculat; calculator mdlDimStyle_setBoolIntProp (dgnDimStyle_getActiveFromModelRef (0), FLAG, TERMTYPE)
where,
TERMTYPE = 717 : Arrow
TERMTYPE = 718 : Dot
TERMTYPE = 719 : Origin
TERMTYPE = 720 : Stroke
FLAG = 0 : Extend dimension line all the way to extension line
FLAG = 1 : Do not extend
