Document Type: FAQ
Product(s): LEAP RCPIER/Substructure
Version(s): All
Original Author: Bentley Technical Support Group -VM
ANSWER:
In RC pier to transfer the load from superstructure to substructure it is required to provide a minimum of 2 bearings. For integral slab by default the program generates the bearings at every 2ft . If the user has to provide the bearings manually then at every 2ft should be fine.
